Clutch Squealing
/ Clutch Squealing #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
After not using the tractor much lately started it today and was hooking up the buhhog. Any time I put much of a strain on it taking off it squeals like crazy. By that I mean anytime you have any rpms at all and let out on the clutch it squeals. What could be the problem?
/ Clutch Squealing #2
May be a bearing, do you hear the squealing just when the mower is hooked up or all the time. Might be rust on the clutch plate also. The noise should stop wit some use if it is rust.TB
/ Clutch Squealing #3
We have an old 2 cyl JD that does this. Does the bush hog have a clutch pack or a shear pin? The problem on the old JD was due to rust on the clutch on the bush hog. I assume when you are letting off the clutch the PTO is engaged? If so, I agree with Texas Bill. It is probably due to rust on the bush hog clutch.
/ Clutch Squealing #4
Are we talking engaging pto clutch or transmission clutch?
Will
/ Clutch Squealing
Tranny clutch. only when i have the rpms high it squeals. it's definately in the tractor. isn't going away so it is not rust.
/ Clutch Squealing #6
</font><font color="blue" class="small">( Tranny clutch. only when i have the rpms high it squeals. it's definately in the tractor. isn't going away so it is not rust. )</font>
How much pedal do you have when letting the clutch out> It may need adjusted and isn't engaging completely.
/ Clutch Squealing
Adjusted it and it still does it. Everything seems to be engaging correctly and it pulls fine it just squeals for a second when you first let out.
/ Clutch Squealing #8
Do you see any evidence of oil or hydraulic leaks around the clutch housing?
213086 (A64276)
213086 (A64276)
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
2021 Kubota KX080-4 (A64126)
2021 Kubota...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
