Price Check Clutch Replacement pricing
   / Clutch Replacement pricing #11
yea the clutch kit aint but about 700 dollars for everything give or take 100 depending on which disc is in the tractor and about 8 hours to split and put back together
   / Clutch Replacement pricing #12
That is inline around here as well. Ken Sweet
unless I get some more concrete poured, and some monster jack stands and a GOOD roll around floor jack.. one of you guys may be getting my business when my 5000 does decide to need a clutch.. :) if she holds out another couple years.. I might be able to swing the equipment and 'crete.. but it's not in the budget right now.. :)
soundguy
   / Clutch Replacement pricing #13
our only good tractor mechanic here recently closed, leaving the cnh dealership as the only viable mechanic within 90m that works on tractors. and i'm afraid to say that they gounge 2x to 3x the going price.. for service / labor ( though their parts and supplies seem to be inline with most other numbers I see ).
soundguy
   / Clutch Replacement pricing #14
Thats normally how it goes when everybody else goes out of buiseness the one still there just ask more because where else it there to go
soundguy
That's exactly my situation. Only one guy in the area and he's not interested enough to even return calls. I thought we were in a recession but go figure. So I have mine hauled 80 miles to be worked on. My old dealer was 40 miles away but they went under so what's one to do. I have four CNH dealers that痴 around 80 miles so I chose the one that was more responsive to my issue and they only charged $140 for pickup/delivery. Others want $95 per hour or $600. Like crap, I'll put that money into a trailer before I spend that. At this point I pleased with my new dealer.... let's hope it stays that way!
   / Clutch Replacement pricing #16
if having expensive work done, our dealer will pickup and haul from my area for 100$.. before I had my big trailer.. I let him.. that's a fair price.. had to have some hyd work done on my 7610s.. now that I got a trailer big enough to haul it.. I will save that.. as it looks like i'll need it for repair money... :)
soundguy
   / Clutch Replacement pricing #17
soundguy
WHAT!!!-----no heated/ac 6000 sq ft play pen--- just spend the money----think of all the projects and fun you can have!!!!:cool:
   / Clutch Replacement pricing #18
just had to put in a 1600+ sq barn building.. ate up my construction project cashola.. :)
soundguy
   / Clutch Replacement pricing #19
I got a quote for replacing my clutch at my dealer. $2,500
$1,500 of that is just for a new clutch not including labor. I'm getting pricing on remanufactured one now... hope they are cheaper. I'm told it's a double clutch and they are expensive. Is $1,500 out of line... the other $1,000 is for labor and transporting.
My other option is replacing only the throw out bearing and hope for the best on the other parts. They said the other parts are worn and my last a year???? Just replacing the bearing would cost $1,200 total (labor, transporting and bearing). thanks, Bob
Your TN75 weighs about 6000 lb--roughly the weight of a 1-ton pickup.
A few 10Klb bottle jacks, some 6x6 cribbing and one or two decent floor jacks will be enough to handle the tractor splitting. Once the tractor is split, working on the clutch is pretty easy.
If $2.5K is a problem, then get the parts and DIY. A good way to learn tractor repair.
   / Clutch Replacement pricing #20
the tn series tractor has alot of specialty tools u need to change the clutch that cost about what they quoted to do the job for u so the diy method so be out unless u like spending money
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2005 Interstate 7x14 Trailer (A55973)
2005 Interstate...
Cushman Cart (A55853)
2020 Prime Time Avenger ATI 26BK 28ft. T/A Travel Trailer (A55853)
2020 Prime Time...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
