Clutch Removal John Deere S1400 Trimmer
   / Clutch Removal John Deere S1400 Trimmer #1
falcon64
Hi guys,
Need to know the correct procedure for removing the clutch assembly from a John Deere S1400 trimmer. I need to remove the starter cover to obtain clearance to drill out and extract a broken muffler mounting bolt. Any help would be greatly appreciated. Below is the link to a photo of the engine. Thanks!
   / Clutch Removal John Deere S1400 Trimmer #2
Look up in snout for torx head bolt. Then you'll need to lock down the piston so you can unscrew. A piece of recoil rope fed in the sparkplug hole will do it
joecdeere,
Thanks for the help! Do you know by chance which direction to turn the clutch to loosen it? When you pull the starter the crank rotates counter clockwise, so I assumed it would loosen by going clockwise.
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2017 Chevrolet Tahoe (A52377)
2017 Chevrolet...
72'' root grapple (A53421)
72'' root grapple...
2005 TerraGator 8104 (A53473)
2005 TerraGator...
3/16Th Plate Steel (A52377)
3/16Th Plate Steel...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
