Clutch fluid
   / Clutch fluid #2
Get an operators manual for your tractor. This information and other valuable info will be available to you
   / Clutch fluid #3
My Ford transmission has a dip stick just like the engine oil. The rear end, where the hydraulic pump and reservoir are located, has a plug on the side. When you remove the plug, oil runs out if at the correct level.
As mentioned, get an owner/operator's manual. You'll need it.
   / Clutch fluid #4
Manner of checking fluid varies greatly among various tractor brands as well as by model and year. That is why the owner's manual is so important.
   / Clutch fluid #5
Some have a dipstick on top. I assume since you are asking yours does not;). Generally, there is a drain plug, a side nipple, and a fill cap. Unscrew the nipple from the side of the housing. On a lot of fords, I think it is a 1/4. If fluid runs out, it is full. If not, pour through the top until it does.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2012 Ram 3500 Chassis Pickup Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2013 HINO CONV. ICE CREAM TRUCK (A52472)
2013 HINO CONV...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
