Clutch drive disk removal
   / Clutch drive disk removal #1
1952a
John Deere A
My drive disk is rusted on the crankshaft. I have tried soaking it and a gear puller and also some heat. Will I ruin any seals if I get it good an hot? Thanks in advance.
   / Clutch drive disk removal #2
If you apply the heat to the disc hub you should be ok. I'm thinking it sits on a tapered spline. When it moves that first .005" it will jump right out at you.
   / Clutch drive disk removal #3
If you can come up with a way to attach one a slide hammer may do the trick.
   / Clutch drive disk removal #4
Ditto on splined crankshaft which will require heat & puller. Strike puller center bolt with a big hammer. IIRC RH side of 2 cylinder crankshaft has no seal only an oil slinger.
   / Clutch drive disk removal #5
Jim is it a straight spline or tapered?
   / Clutch drive disk removal #6
Have you tried the atf/acetone mix? Might be worth a shot. Mix it 50/50 and keep in a sealed container. Has worked for me when I thought nothing would. JM2C.
2003 International 24ft 4200 Box Truck (A51692)
2003 International...
2012 Mazada 3 Sedan (A51694)
2012 Mazada 3...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
2022 PETERBILT 579 DAY CAB (A53426)
2022 PETERBILT 579...
