Clutch drive disk removal
/ Clutch drive disk removal #1
1952a
John Deere A
My drive disk is rusted on the crankshaft. I have tried soaking it and a gear puller and also some heat. Will I ruin any seals if I get it good an hot? Thanks in advance.
/ Clutch drive disk removal #2
If you apply the heat to the disc hub you should be ok. I'm thinking it sits on a tapered spline. When it moves that first .005" it will jump right out at you.
/ Clutch drive disk removal #3
If you can come up with a way to attach one a slide hammer may do the trick.
/ Clutch drive disk removal #4
Ditto on splined crankshaft which will require heat & puller. Strike puller center bolt with a big hammer. IIRC RH side of 2 cylinder crankshaft has no seal only an oil slinger.
/ Clutch drive disk removal #6
Have you tried the atf/acetone mix? Might be worth a shot. Mix it 50/50 and keep in a sealed container. Has worked for me when I thought nothing would. JM2C.
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2014 FORD F-250 (A60736)
2014 FORD F-250...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
832717 (A61166)
832717 (A61166)
