Clutch drive disk removal
   / Clutch drive disk removal #1
1952a
John Deere A
My drive disk is rusted on the crankshaft. I have tried soaking it and a gear puller and also some heat. Will I ruin any seals if I get it good an hot? Thanks in advance.
   / Clutch drive disk removal #2
If you apply the heat to the disc hub you should be ok. I'm thinking it sits on a tapered spline. When it moves that first .005" it will jump right out at you.
   / Clutch drive disk removal #3
If you can come up with a way to attach one a slide hammer may do the trick.
   / Clutch drive disk removal #4
Ditto on splined crankshaft which will require heat & puller. Strike puller center bolt with a big hammer. IIRC RH side of 2 cylinder crankshaft has no seal only an oil slinger.
   / Clutch drive disk removal #5
Jim is it a straight spline or tapered?
   / Clutch drive disk removal #6
Have you tried the atf/acetone mix? Might be worth a shot. Mix it 50/50 and keep in a sealed container. Has worked for me when I thought nothing would. JM2C.
1268 (A50490)
1268 (A50490)
Wacker Neuson G25 20kW Towable Diesel Generator (A51691)
Wacker Neuson G25...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A53426)
1968 CHEVROLET C10...
