clutch add-on
/ clutch add-on #1
rockinmywaypa
Platinum Member
under the elephant\'s tail [ ontario can.]
john deere 3130, universal case 970 and a IH 1086
I would like to take an engine that was on a swather with a variable belt drive and convert it to drive a pto shaft. I would like to have a clutch while eliminating the belt. Does anyone know of anything that would suit the purpose as a clutch and stand up to about 40 hp input. The application is to mount the motor in front of a tmr mixer wagon by extending the tongue so that I can move it with the same tractor that I load it with and then can start it up to unload later in the day and not have to start up an 80 hp diesel in sub freezing weather. I am hoping I can come up with a straight through design instead of side stepping out and back with pulleys but I can if I absolutely have to.
Thanks in advance.
/ clutch add-on #2
an electric clutch, possibly off a combine, I do not know about straight line,
/ clutch add-on #3
My saw mill has a Rockford Clutch that bolts on to a John Deere engine. You engage the clutch with a hand lever. The output shaft is in line with the output of the engine.
John Deere 2840 Tractor (A64047)
John Deere 2840...
40' CONTAINER (A64281)
International S1900 (A63689)
International...
UNUSED WOLVERINE PT-16-01C 3 PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
