clutch add-on
   / clutch add-on #1
rockinmywaypa
Platinum Member
under the elephant\'s tail [ ontario can.]
john deere 3130, universal case 970 and a IH 1086
I would like to take an engine that was on a swather with a variable belt drive and convert it to drive a pto shaft. I would like to have a clutch while eliminating the belt. Does anyone know of anything that would suit the purpose as a clutch and stand up to about 40 hp input. The application is to mount the motor in front of a tmr mixer wagon by extending the tongue so that I can move it with the same tractor that I load it with and then can start it up to unload later in the day and not have to start up an 80 hp diesel in sub freezing weather. I am hoping I can come up with a straight through design instead of side stepping out and back with pulleys but I can if I absolutely have to.
Thanks in advance.
   / clutch add-on #2
an electric clutch, possibly off a combine, I do not know about straight line,
   / clutch add-on #3
My saw mill has a Rockford Clutch that bolts on to a John Deere engine. You engage the clutch with a hand lever. The output shaft is in line with the output of the engine.
   / clutch add-on
That would be the ideal product, I'll see if I can track one down. Thank you for your post, first one and helpful as can be.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
