Club Cadet RZT 42in transaxle trouble
   / Club Cadet RZT 42in transaxle trouble #1
Chuckzforce
gore , Oklahoma
2006 Club Cadet Zforce
I'm having trouble with the transaxle . One week they worked and the next they didn't . I can't find a plug to add more fluid . Help please. Thanks
   / Club Cadet RZT 42in transaxle trouble #2
A first thought may be that either the bypass levers are in the disengage mode or the belt failed / lost tension.
   / Club Cadet RZT 42in transaxle trouble #3
Indeed Tom. What diagnostic has led you to the conclusion that you need to "add more fluid" Chuck?? :confused3:
I just can't figure anything else out the bypass levers are engaged belt, and everything else seems to be good.
   / Club Cadet RZT 42in transaxle trouble #5
For both drives to fail at the same time would be odd. I would be checking belt tension among other things .. if one failed I could see a problem, but not both at the same time.
Thanks
   / Club Cadet RZT 42in transaxle trouble #7
I would trust Randyt suggestions. I have a suspicion he has worked on a lot of sma'll engines and mowers. He diagnosed my problem to the "T". I would put quite a bit of weight in his thoughts and suggestions.
OK thank you I'll check it out
   / Club Cadet RZT 42in transaxle trouble #9
20 years
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A56858)
2008 Ford E-350...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
