Club Cadet RZT 42in transaxle trouble
   / Club Cadet RZT 42in transaxle trouble #1
Chuckzforce
gore , Oklahoma
2006 Club Cadet Zforce
I'm having trouble with the transaxle . One week they worked and the next they didn't . I can't find a plug to add more fluid . Help please. Thanks
   / Club Cadet RZT 42in transaxle trouble #2
A first thought may be that either the bypass levers are in the disengage mode or the belt failed / lost tension.
   / Club Cadet RZT 42in transaxle trouble #3
Indeed Tom. What diagnostic has led you to the conclusion that you need to "add more fluid" Chuck?? :confused3:
I just can't figure anything else out the bypass levers are engaged belt, and everything else seems to be good.
   / Club Cadet RZT 42in transaxle trouble #5
For both drives to fail at the same time would be odd. I would be checking belt tension among other things .. if one failed I could see a problem, but not both at the same time.
Thanks
   / Club Cadet RZT 42in transaxle trouble #7
I would trust Randyt suggestions. I have a suspicion he has worked on a lot of sma'll engines and mowers. He diagnosed my problem to the "T". I would put quite a bit of weight in his thoughts and suggestions.
OK thank you I'll check it out
   / Club Cadet RZT 42in transaxle trouble #9
20 years
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
