Close call changing front diff. oil
/ Close call changing front diff. oil #1
PlanMan
Upstate NY
Kubota B7200
Thought I would share my experience for safety's sake:
I bought a used Kubota with low hrs. and was changing all fluids/filters etc.
The tractor was not overly hot, I pulled it out of the garage & let it idle in the driveway for about 10 minutes.
While removing the drain plug on the front differential, as it neared the last thread, it suddenly blew out, hit the tire, & shot gear oil out for a distance of 5 ft. from the tractor, soaking my arm and my driveway. I feel fortunate not to have taken it in the face / eyes.
I attribute it to the previous owner over-filling the differential and possibly using an oil that foamed, adding to the condition, but please advise if anyone knows what else might have caused this.
/ Close call changing front diff. oil #2
WOW!! Never heard of that before. Usually the seals and plugs would leak if there was that much pressure. I don't think that unit is connected to the engine either.
Wonder what happened to. At least you know the oil seals are in good shape.
Was there foam in the oil?
/ Close call changing front diff. oil #3
I'm really not familiar with your model Kubota, but mine had short curved vent tubes on top of the front axle, so I would assume yours does, too, and that the vent is plugged and needs to be cleaned out.
/ Close call changing front diff. oil #4
Just curious, was the outside of the differential or the plug hot?
RobJ, Egon, & Bird,
Thanks for the replies -
1. Neither the differential nor the plug were hot. I let the machine idle up to temp in the driveway and had not used it.
2. No discoloration in the oil, dark gray/black. No water.
3. Bird, I checked my owners manual and parts manual. No vent on this unit. I have a friend who teaches heavy equipment repair and that's the first thing he said also - the vent's plugged. It's a 1990. I'll post a pic.
Just thought it was worth posting so someone else might keep it in mind if they have an older machine without vents.
/ Close call changing front diff. oil #6
I always wear glasses when working on my tractor. Always.
Thank goodness you were not injured.
Bob
/ Close call changing front diff. oil #7
I have a ford tractor with four wheel drive. It also has no vent. And I have replaced seals etc. before. But the filler/dip stick, would build pressure and push the oil past the sealed.
I replaced the filler?dip plug with a piece of PVC pipe and a cap. (1/2 inch cpvc)..The 1/2 inch threads almost fit, but they would fit tight enough to seal.I drilled several small holes int he side of the cap to let it vent.
Haven't had any pressure pushing the oil past since.
I just Carry the original plug, and use it when checking the oil level.
But if your not having the seals leak, perhaps you shouldnt "vent" it.
/ Close call changing front diff. oil #8
I think Bedlam had the right idea. I'd be making a vent for it one way or another before I had to replace seals.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
213133 (A64276)
213133 (A64276)
96"X18' TRI-AXLE TRAILER (A64280)
96"X18' TRI-AXLE...
2002 48ft. 38 Ton T/A Flatbed Trailer (A61573)
2002 48ft. 38 Ton...
(5) MISC WHEELED TRASH CANS (A64280)
(5) MISC WHEELED...
