Clogged suction screen
/ Clogged suction screen #1
wgmoates
Lebanon, TN
John Deere 5105
I have a JD 5105 that lost hydraulics. Upon draining the fluid and checking the screen, I found it to be clogged with what appeared to be brown granular substance. My first thought was brake disk material, I had recently adjusted the brake pedal play because I had lost brakes. I have attached a photo.
Any advice on how to proceed, or what this material is?
/ Clogged suction screen #2
oily rust?
/ Clogged suction screen #3
Clean it an recheck after running awhile. Your right the brakes have to go someplace.
/ Clogged suction screen #5
If you put a magnet on it that crud, will it stick? If its not magnetic, I would be afraid that it is parts of the brake lining.
/ Clogged suction screen #6
It looks like some of it is very large flakes of rust. Have you ever had water contamination in your oil? When is the last time you changed the hydraulic oil? I don't think I have ever seen a reservoir rust before nor seen brake dust be anything more than a gray sludge on a screen. I don't have a clue as to where that came from if it is indeed rust particles.
I don't beleive it is rust, it seems to be non metallic. The hydraulic oil was changed 2 years ago, less than 100 hours since then. I did clean the screen, pour the fluid back in through a screen, and things seem to work fine. I am concerned that it may be brake lining, although I still have some brakes, not great though.
If the brake disks need to be replaced in the future I don't think I can pull it off with my limited tools and skill level, I looked at the technical manual and it seems somewhat involved.
I will use it for a bush hog job or two and then drain and inspect the screen again. Not sure what else to do at this point. Any advice most appreciated.
/ Clogged suction screen #8
Looks like a seal kit gone bad in a hydraulic cylinder possibly.
/ Clogged suction screen #9
I'm afraid that the disintegrated brake lining theory is the most likely. IMHO.
