Clog indicator
/ Clog indicator #1
TXAG
College Station, TX
Mahindra 4530
I just drove into town and filled up the tank on my 4530 with diesel. Went home and got to work and noticed that the "clog indicator" was on. I checked the book and it just says it is a clog indicator. Doesn't indicate what is clogged but everything seems to be working just fine. No problems lifting on either end, engine runs fine. Filled my pickup up at the same location and it is also running fine. So I guess my question is "what is clogged?"
/ Clog indicator #2
On my 6500 I had this. Mine was from the air filter. I think they replaced the sensor. Before that I cleaned the filter (which was brand new and clean anyway) and put it back but the warning stayed on. Probably a sensor or a dirty air filter.
/ Clog indicator #3
Tim is correct, it is probably either a bad sensor or your air filter is stopped up. IF it is the sensor it is a very easy fix.
/ Clog indicator
Thanks for the info on where to even start looking. There are so many things that can be clogged I didn't have a clue where to begin.
/ Clog indicator #5
Where is this "Clog Indicator?" Is it a dash light?
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
