Climate Controls for 40xxR series cab tractors
   / Climate Controls for 40xxR series cab tractors #12
JD 4320 compact. I have the low heat problem when the tractor idles. I replaced my water pump about 7-8 years ago with the std replacement. Didn't realize/know that they make a high volume water pump. It has like a 2.62 dia impeller versus the 2.0?? maybe. If I ever replace it again i will put in the high volume pump. If anybody changes out there water pump you need new bolts because they are they torque turn setup. Later.
   / Climate Controls for 40xxR series cab tractors #13
I forgot one other thing, Maybe you have a air pocket in the heater circuit. Later
   / Climate Controls for 40xxR series cab tractors #14
Sorry for the info but my tractor is an older 4000 series. Disregard the above on the high volume water pump.
Got a great chance to use the cab heat today...blowing about 12" of powdery snow.
Heat works fine! In fact, since I was wearing insulated coveralls, I had to turn it down.
I hope the AC works as well!
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
FENCE PANELS (A58216)
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2016 John Deere HPXD (A57149)
2016 John Deere...
1991 CAT D7H Crawler Dozer (A59213)
1991 CAT D7H...
