Climate Controls for 40xxR series cab tractors
   / Climate Controls for 40xxR series cab tractors #12
JD 4320 compact. I have the low heat problem when the tractor idles. I replaced my water pump about 7-8 years ago with the std replacement. Didn't realize/know that they make a high volume water pump. It has like a 2.62 dia impeller versus the 2.0?? maybe. If I ever replace it again i will put in the high volume pump. If anybody changes out there water pump you need new bolts because they are they torque turn setup. Later.
   / Climate Controls for 40xxR series cab tractors #13
I forgot one other thing, Maybe you have a air pocket in the heater circuit. Later
   / Climate Controls for 40xxR series cab tractors #14
Sorry for the info but my tractor is an older 4000 series. Disregard the above on the high volume water pump.
Got a great chance to use the cab heat today...blowing about 12" of powdery snow.
Heat works fine! In fact, since I was wearing insulated coveralls, I had to turn it down.
I hope the AC works as well!
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
1999 CPS TRAILER COMPANY BELLY DUMP TRAILER (A58214)
1999 CPS TRAILER...
19008 (A56859)
19008 (A56859)
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2368 (A58376)
2368 (A58376)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
