Clicking Noise from Right Rear Wheel Area
   / Clicking Noise from Right Rear Wheel Area #1
richriddle
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
On the Yanmar YM276D a slight clicking noise occurs every ten or fifteen feet of travel on the right side. Do any of you folks have any idea what that might be?
   / Clicking Noise from Right Rear Wheel Area #2
Could be loose wheel bolts.
First thing I would check with those symptoms.
   / Clicking Noise from Right Rear Wheel Area #3
Ditto.
I had forgotten until reading this that my YM240 squeaked as it rolled along. Lose lug nuts, one of many 'deferred maintenance' issues I corrected before putting it in service.
And the YM186D has adjustable width rear hubs/axles, they will click if the tensioning bolt isn't torqued. These need to be checked every 100 hours or so. (But probably not relevant for a YM276D).
Unlikely but could that be a tubeless tire with debris inside?
   / Clicking Noise from Right Rear Wheel Area #4
Just for yucks and the experience
Remove the wheel, then the hub and look at the bare axle. The parts are not "that heavy" , Use common sense along with good wrenches and good jack stands.
It's "cheap education" if you do it right.!
   / Clicking Noise from Right Rear Wheel Area #5
That's likely it and tighten ASAP before you crack the wheel.
   / Clicking Noise from Right Rear Wheel Area #8
   / Clicking Noise from Right Rear Wheel Area #10
Jack up and block the rear of the tractor and then use a pry bar to move/lift the tire.
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
2009 Chevrolet TrailBlazer Multipurpose Vehicle (A51694)
2009 Chevrolet...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
