Clicking Noise from Right Rear Wheel Area
   / Clicking Noise from Right Rear Wheel Area #1
richriddle
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
On the Yanmar YM276D a slight clicking noise occurs every ten or fifteen feet of travel on the right side. Do any of you folks have any idea what that might be?
   / Clicking Noise from Right Rear Wheel Area #2
Could be loose wheel bolts.
First thing I would check with those symptoms.
   / Clicking Noise from Right Rear Wheel Area #3
Ditto.
I had forgotten until reading this that my YM240 squeaked as it rolled along. Lose lug nuts, one of many 'deferred maintenance' issues I corrected before putting it in service.
And the YM186D has adjustable width rear hubs/axles, they will click if the tensioning bolt isn't torqued. These need to be checked every 100 hours or so. (But probably not relevant for a YM276D).
Unlikely but could that be a tubeless tire with debris inside?
   / Clicking Noise from Right Rear Wheel Area #4
Just for yucks and the experience
Remove the wheel, then the hub and look at the bare axle. The parts are not "that heavy" , Use common sense along with good wrenches and good jack stands.
It's "cheap education" if you do it right.!
   / Clicking Noise from Right Rear Wheel Area #5
That's likely it and tighten ASAP before you crack the wheel.
   / Clicking Noise from Right Rear Wheel Area #8
   / Clicking Noise from Right Rear Wheel Area #10
Jack up and block the rear of the tractor and then use a pry bar to move/lift the tire.
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
