Clearing Old Cutover / 150 acres
/ Clearing Old Cutover / 150 acres #21
Are you sure on the nitrogen thing?
Sureley it's the same as straw or crop residue in a field for the first year it takes nitrogen from the soil to start the process then once it has begun to decompose then it produces nitrogen . I would prefer to see it burned particularly if it's pine / fir etc .
/ Clearing Old Cutover / 150 acres #22
Hahaha. Man this is worse than one of the Ford VS. Chevy VS. Dodge threads I've read elsewhere. :laughing: Those that have a dozer want to doze it, and those with a mulcher want to mulch it. :laughing:
I think the op needs to do some looking and talking to local land owners who have had this type of work done. Take a look at some done with a dozer, and some done with a mulcher. To be fair, try to find jobs that have been done about a year. See which one suites your expectations best and go from there.
I'm looking for some pictures of some stuff I did, about a year or so after completion. Problem is I don't do much clearing, it's mostly thinning. But around here native grasses usually grow back in less than a year after mulching.
/ Clearing Old Cutover / 150 acres #23
It's defiantly ford . Lol
All I know is the guys that bought munchers . All went out of business . And all I see took years for grass to grow .
All the dozer people have been in business for years and years and are still here and not going anywhere . After doz'n you have grass as fast as grass can grow .
Sent from my iPhone 5 using TractorByNet
/ Clearing Old Cutover / 150 acres #24
That's what I have been told by agriculture and forestry consultants, silviculturist's, and others more educated than me.:)
Do a google on mulch and nitrogen. Then find some new advisers!
Wood Mulch Pros and Cons:
Initial application can rob some nitrogen from the soil; you may need to supplement nitrogen for your plants. Since wood itself contains very little nitrogen it helps itself to N already present in the soil to break down its carbohydrates. When the decomposing process is complete the nitrogen will then be returned to the soil. See organic soil amendment chart for sources of nitrogen. A surface mulch of wood will only take nitrogen from the top of the soil surface whereas any wood mulch worked into the soil will readily consume the nitrogen.
Avoid aspen, black walnut, and black locust in wood mulches.
You do not want mulch that comes from diseased plants. This should be thrown out.
Wood mulches can sometimes harbor insects and rodents i.e.: watch out for borers (very destructive bugs) and mice. Here again it is best to keep mulch pulled back from the plant base to make it unattractive for rodent nesting and burrowing.
Hard to clean leaves and garden debris out of wood mulch.
Retains moisture very well.
Keeps the soil cool during hot weather and warms it in early spring.
Wood mulch is very appealing. Looks great when used around evergreens and perennial plantings.
Cedar makes for a superior mulch as it has insect repellant properties.
Some good choices: cypress, cedar, redwood, willow and pine.
/ Clearing Old Cutover / 150 acres #25
I've been in the mulching business for 6 years. Every job that I did a year ago is 3 or more feet tall with all kinds of vegetation. Unless the landowner has kept it mowed down.
Every customer was very happy with the results. Most of them also say they wanted it mulched because they were concerned about losing the topsoil and did not want to have huge piles to burn later.
I would say that preserving the soil is a big issue for me. We don't have very good soil in our area to begin with. The last area we had dozer work done took years to produce adequately. Another issue is rocks. If we clear the land with a dozer we are going to bring up a ton of rocks that will have to be cleared.
The dozer with shear blade sounds interesting but you would still have all the burn piles to deal with and then follow up with the grading.
If it were mulched we have a 15 ft bush hog to control regrowth.
If prices were equal it would seem to me that mulching would be the way to go.
Right now the only way I can see us affording to do this is if we purchase the equipment and do it ourself, whether it is a used dozer or mulcher.
When looking at used mulchers on some of the equipment auction sites it seems like some of the big equipment might be cheaper to buy. I saw some older Hydro Ax with mulching head sold for $50 - $60 thousand. These were older auctions so something might have pushed the prices down; economy, timing, season. They could have been worn out. I don't know.
What type of production can you get out of one of the larger pieces of equipment like a Hydro Ax?
I know there is a lot to consider when buying used equipment. But that applies with whatever you buy.
I know you have to look at equipment invidually but what hours of use does it start to concern you for the different types of equipment? When is a skid steer type worn out? What is high hours for a Gyro Trac GT25 or equivalent? Probably hard to say. So much depends on what type of work each is doing.
/ Clearing Old Cutover / 150 acres #28
I know this is beginning to be a touchy thread. I had a past customer to tell me yesterday that his son in law hired a dozer to clear an acre and a half of woods. Charged him $3400! I walked the property with him yesterday and the largest tree in the pile was 7-8". Maybe 10 or 12 of them. Now the county will not let him burn cause of churches and elderly near by. So you either bury it and it cave in a few years later, haul it off, or back to mulch it. From my work experience in the past, I have mulched property and 2 days later there is a mobile home on it and grass a year later not weeds, grass. This other property can't move a home on it cause the soil won't hold up. Opinions are like but holes, everyone has one! That is mine. What's easier for your cattle/tractor to walk/drive over the fastest and smoothest.
/ Clearing Old Cutover / 150 acres #29
It really depends on the equipments operator. If he is a owner or an operator. Also there are some dealers that will service a used machine and give you a quote on warranty a year at the time. That's worth looking into to save you some money and down time.
/ Clearing Old Cutover / 150 acres #30
The way I look at it isn't which is faster and better at clearing land, both have their places. What I'm concerned with if he buys a mulcher that somebody abuse the heck out of!! Most of the used mulchers come from guys who ran the tar out of it, they come through with a MIG welder and fix the cosmetics and make sure it will at least crank up and run to get on the trailer! When you get your machine home and start mulching and say "hey! This machine is fantastic!!" It blows a lift pump or if its a gyrotrac the undercarriage need all new hubs and bearings!! I just left a job were their GT-25 would only run for 5 hours and be down for 2 days for repairs!! That's alot of $$$$ to throw on a dead horse. All the guys who run mulchers right keep them! The ones for sale half the time are ones a owner had and his " professional" operator ruined and he's trying to pay his repair bills by selling it. A dozer to me may not be quicker or cleaner, but you have real dealers local and can get parts right off the shelf, not call halfway across the country to have a rep tell you he doesn't have it or it'll be a week or two. I like mulchers when they are new, not when you buy somebody else's problems!
As far as replanting goes, the last 250acre job I did we had milliet growing on it in 2 months, a shear blade floats on the ground or a little deeper and gets everything, then you rake it and roll the dirt out of the piles, since you said you have rocks, a heavy duty carbide tooth mulcher is all you could use, unless you wanted to replace teeth every time your planer head mulcher touches the ground, you would leave more stobs and stumps higher off the ground either way.
And one last resort is a drum chopper pulled by a rented dozer, won't be as clean, but I won't destroy the dirt and bring up rocks, with a few years of burning and letting cattle stomp it down, it will look pretty decent
/ Clearing Old Cutover / 150 acres #31
Is cutting fire breaks and doing a controlled burn out of the question? If you only have limited 6" material I would think a controlled burn would take care of everything (except pine trees) 4" and under. You would probably need to buy or hire a good sized dozer or 80+hp tractor and disk/plow some sizable fire lines and burn maybe 20 acres at a time.
/ Clearing Old Cutover / 150 acres #32
A control burn is Really good for the soil. The thing is, that the small trees and underbrush will still be standing. Most of it will be very rigid for quite awhile. Especially the 4 - 6" diameter trees.
/ Clearing Old Cutover / 150 acres #33
crossroadsd, if the photo's shown in your first post are indicative of the vegetation of want cleared then I would recommend mulching for the following reasons.
1; It is lightly vegetated so you will only get a very light cover of mulch and the grasses you want should appear fairly quickly.
2; Zero till should be easy if you want to reseed.
3; If you want to do this work your self, I suggest using a wheel tractor (farm type) around 200hp and PTO driven mulcher (Fecon, FAE can supply). After the land is cleared you can sell the mulcher and keep the tractor for all the other duties on your on your farm. Buying a used dedicated mulcher can have some serious pitfalls and some can be bad enough new.:(
4; Because it's lightly vegetated a dozer will have to push timber a fair way to make a decent heap and in doing so will create quite a lot of ground disturbance.
5; Quality isn't expensive, it's priceless.
I wish you well with your project and look forward to your updates however you decide to do it :thumbsup:
/ Clearing Old Cutover / 150 acres #34
Tony, you may have a point here! Red, can you think of any challenges in used mulchers? :laughing: Seems like maybe I've read something somewhere...:laughing: Carl
/ Clearing Old Cutover / 150 acres #35
Challenges? What challenges? I can't think of any challenges I could have had with used machines. :laughing:
Really though, I walked into my Fecon with both eyes open. I bought it cheap enough that I could afford to put a new engine in it. Unfortunately, these things always happen at the most inopportune time....And besides that, there's nothing like stripping a machine down to it's bare skeleton to give you an intimate understanding of it's inner workings. :laughing:
Brand new machines can be challenging at times as well. You may not remember my adventure with a Terex PT-100G. :eek:
/ Clearing Old Cutover / 150 acres #36
Spray it then burn it would get rid of a bunch of that.
I'm in the same boat as the OP (but on a smaller scale) and need to clean up about 25 acres of cutover that I want to put into pasture.
After a bunch of research I went with the spray and burn approach. Everything was sprayed a few months ago ($85 per acre) and is set to be burned soon ($25 per acre). Far cheaper than either mulching or a dozer with a shear blade and no topsoil disturbance issues.
/ Clearing Old Cutover / 150 acres #37
I don't know how a burn would work where the OP lives, but this was burned in a forest fire 13 years ago.
Not near as much rot as you'd think either.
Look into it good before choosing a burn to create a clearcut. You could have this kind of stuff to deal with too.
/ Clearing Old Cutover / 150 acres #38
That's alot of snags to cut hahahah!!!
/ Clearing Old Cutover / 150 acres #39
Yes sir it is.
Here's the stuff off of about 6 acres that was to hard to mulch.
The rest of it mulched up pretty good.
/ Clearing Old Cutover / 150 acres #40
I'll tell ya what Red!! I wish our operator with that bron could make half of his work look like that!! Did ya haul the logs of for anything merchantable?
UNUSED RAYTREE ARTICULATING BRUH CUTTER (A62131)
UNUSED RAYTREE...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
2016 Deere 180G (A60462)
2016 Deere 180G...
