Clearing land
/ Clearing land #1
1falcondriver
John Deere 4610 4x4
I'm new to the forum...just bought 15 acres of land and a JD 4610 (4x4 fel). I need to clear the land. It's a pine plantation about 18 years old. I won't be clear cutting just cleaning up for a house place. What brush cutter should I be looking for? Most of the stuff I'll be cutting is 3" or smaller around the pines?
The 4610 is 43hp 37@the PTO
/ Clearing land #2
If you just use a cutter, you will end up with stubs sticking up, not a very nice home environment and not one easy to keep mowed.
I had a situation like yours years ago although the trees were a bit bigger (4-5") and were red maple. I cut them off a couple of feet high with a chain saw, then used the ripper teeth on a box blade to pull the stumps. Some were harder and I used a single big tooth ripper attachment. I probably should have cut them off shorter, more like 6-12" high.
That's all I had for equipment back then. Now I would recommend a backhoe (rent one if you need to) to do the work.
Ken
1998 Toro ProLine 36in Stand On Mower (A64194)
1998 Toro ProLine...
2017 DITCH WITCH JT20 HORIZONTAL DRILL (A63276)
2017 DITCH WITCH...
2017 Ford E-450 Super Duty Shuttle Bus (A64556)
2017 Ford E-450...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
Wooden Table (A64557)
2015 Volvo L110H Articulated Wheel Loader (A64553)
2015 Volvo L110H...
