CTW, I know right where you are
I've got relatives in both the Corpus and Victoria area.
As you doubtless know, people have been root plowing and chaining and bulldozing mesquite down there since the late 50's... if it was easy, the thickets would have been removed by now.
Your county agent will be your best source of info.... and, even if you do go the mechanical approach, be prepared to continue the fight for at least another 5 years... plan for it now... this is not a one time thing....No technique will be 100%.. and that is your aim...100% removal..else infestation will reoccur... just drive around...notice the various heights of the mesquite in your neighbor's pastures... then ask them how long it has been since they sought to controll mesquite. Moral...it comes back ifyou don't follow up aggressively for numerous years. Also, what is your pear situation? Typically, mechanical removal of mesquite tears up lots of pear and allows it to spread really fast... causing another pernicious problem.
There are various solutions/mixes for reclaim... I have had good success with a mix that includes small amounts of reclaim, some diesel, surficant, and water...I mixed it in a 300 gallon tank... with 5 gallons of diesel as I recall. timing is significant....as I recall, best is about 70 days after bud break when the leaves are recharging the roots. The chemical moves fromthe leaves directly to the supporting root system and kills it.
Yes, reclaim is expensive....but it is amazingly specific to mesquite.... I sprayed a mesquite bush intertwined with a small oak tree and there was a native vine also in the mix. The mesquite died andthe vine and oak didn't even lose one leaf. You spray exactly the offending tree.
Remedy is another herbicide that I have had very good luck with... it is a basal spray for small plants.
One significant point is that if you spray plants while they are small, then the cost of control is reduced. Let them grow, and your removal cost grows even faster.
PM me if you want further details, etc.
