Clearing Brush, Best Time to do it?
   / Clearing Brush, Best Time to do it? #1
Liberty
I live in Mid South TN. I need to cut some blackberry
bushes, buckle bushes, cedars, locust. On a grown up
farm that I have purchased. I was told by an older
farmer that there are two days in early April that
if the brush is cut it will not come back! I know this
sounds like an old wives tale, it probably is. But I know
a man who knew the person who used to say it and
he said he had done it on the dates when he cleared
his place and it did work amazingly well. The old
farmer has been dead nearly 20 years, my friend
thinks it was 4-4 to 4-6 or 4-10 to 4-12. Has anyone
ever heard this, and if so why might it work?
Thanks, Liberty
   / Clearing Brush, Best Time to do it? #2
April 1st.
   / Clearing Brush, Best Time to do it? #4
Spring is the best time. Different areas may change the dates a little.The blackberry bushes will require spraying with brush killer,digging,pulling them up or numerous mowings in summer when green to kill them. Brush and tree`s are best cutt just before or as the sap begins to rise in the spring.As the elders would say causes them to bleed to death as sap rises from roots to open wound not limbs and leaves.The farmers almanac has listings for the best days discouraging growth or promoting it .
   / Clearing Brush, Best Time to do it? #5
I can tell you from personal experience about blackberies. Cut them befor ethe berry pops out. In fact.. preferable right as they begin to flower. The plant ties up lots of energy into flow and seed. Often you can hit them just right, and then they will try to flower and go to seed a couple weeks later.. You simply hit them again. That usually makes them miss thier seed/bloom window. Also.. you can hit them as they get ready for winter.
I had 10 ac of blackberry and weeds. The first year I owned the property, I tried sprays.. it killed everything for about a month. By the end of the 2nd month.. everything was back. i disked it, and it came back. I payed someone to disc it again.. this time with a big ag disc. That knocked the population down a bit but they still came back almost as bad.
The last couple of years I have simply mowed the heck out of it. I have pensacola bahia on it.. and it grows tall, and grows faste rthan the weeds. As soon as I see the weeds catching up.. i hog it again.. then the grass shoots back up.
I'd guess inthe last 2 years I have cut the BB population down to about 15% of what it used to be... in other words.. less than 1.5 ac of land is covered in BB. if you looked at it like a pie chart distribution.. etc.
Soundguy
   / Clearing Brush, Best Time to do it? #6
As long as we don't have snow, we cut. A week ago we were lucky enough to see 50 temps and we had the brush hog and a grapple working in the woods clearing and cutting. If we get a chance to jump on the New Holland and get some work done then that's a plus.
TC-40D SS web pictures click here
   / Clearing Brush, Best Time to do it? #7
In my part of California, central valley sierra foothills, I only need to cut once in the late spring. The best time is a few weeks after the last rain in late April or early May. If we get a large late rain storm after cutting then I get a little more growth. Elevation and rain fall are big factors in the best time to cut.
On my property I consider it too risky to mow after mid June. Sparks from the mower can start fires in the dry brush.
   / Clearing Brush, Best Time to do it? #8
Nothing kills blackberries. I have a house on the water in Louisiana--the road is called Blackberry Lane--go figure. We let the yard go for a couple of years--it was entirely blackberries. I cut it down, poisoned it etc. Finally I got out a hammer and used the claw to dig out the roots. It took about 40 hours per acre. Dig, dig, dig. Mow mow mow. After several years, its better, but not gone.
We asked a nursery what to use to poison them--they said "yeah, blackberries, good luck".
   / Clearing Brush, Best Time to do it? #9
I too live in southern middle Tenn. and just started on a place my son has bought that is exactly as you described. I'm in the process of bushogging it right now. I didn't want to wait and give the plants any chance to get more established. I plan on doing this now and once about May or June then again late next fall. After that I plan on doing it twice the following year then once a year after that hopefully. It's been my experience that if you keep after it you will make progress on ridding the worst of the plants. Luckily there is some pasture grass under all the mess at my son's place.
   / Clearing Brush, Best Time to do it? #10
Personally I like to mow blackberries when the berry is red and they are pumping to ripen. With winter coming on it seems to knock them back better. They are hard to get rid of, but they won't last long if you keep the mowing going. They don't do well in areas that are maintained. As far as the wives tales, I believe in them. My grandmother swore by the almanac and she planted by the moon and other mistic things. I once saw her plant, actually a limb from a western red cedar, by just sticking it in the ground and she said it would grow because of the moon. It is now a fair size tree. Amazing what we have lost due to "science."
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59575)
2022 KAUFMAN 2 CAR...
