flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,572
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Richard said:We just acquired a International 886. On looking closer at the machine I noticed what appeared to be mud in the fins of the radiator. I surmised that it was a buildup of dust over time and moisture made it solidify.
Spent 45 minutes this morning with hose & hot water going through it, just spraying the radiator from both sides. I was amazed at the amound of muck that worked its way out of the fins. This is a VERY clean looking tractor but there was a ton of crud in the fins.
Later on, when I was cutting one of the fields, I noticed something kind of interesting. The other day when I was cutting, the temp gauge was in the middle of the green. Presumably "normal" range.
Today as I was cutting, (it does happen to be a couple degrees cooler today), none the less, the meter wasn't even IN the green. Was just barely touching the bottom edge of the green.
I presume the crud I cleared out has helped the airflow through the radiator and done that.
Once we get our 10' cutter (I was using a 5') I will expect to put a larger load on the engine and maybe see the temp more in the 'normal' range.
I bought a 1966 MF-135 diesel last July. The radiator air passages were about 3/4 blocked. Took better part of two days to get all the crud out. Otherwise the radiator is fine. Not a trace of gunk in the coolant and it flushes clean as a whistle.
