Cleaning roller pump
/ Cleaning roller pump #21
Thanks for the info guys. The boom won't be any wider than 10' so I'm thinking of a 4 or 6 roller pump.
/ Cleaning roller pump #22
/ Cleaning roller pump #23
I don't have a roller pump so if my question is a dumb one I'm asking forgiveness in advance.
I've been told that a roller pump works by having a set of rollers squeezing a rubber, or perhaps plastic, tube between the rollers and the internal walls of a cylinder. As the rollers are spun around in the housing the solution is pushed along between the sets of rollers. Is this about right?
And there are bearings on the rollers as well as the shaft they are attached to. But the product being pumped through the tube never touches the rollers or the inside of the housing.
So where is this corrosion that seizes the pump coming from?
I can understand that if the bearings get wet from spray drift or spillage they need some grease or oil. But it sounds as though you guys are saying the solution being pumped is causing corrosion.
Help me learn. /forums/images/graemlins/wink.gif
/ Cleaning roller pump #24
/ Cleaning roller pump #25
The Hypro pumps have a rotor with the plastic rollers setting in notches. When the rotor is turned the rollers are forced out against the outer wall of the pump housing. This action is what makes the pump, pump.
Here is a link to a Hypro manual on the model I have. Click Here Drawing of pumps is on page 9-10. You can order them made completely out of stainless steel and other non corrosive materials. I have a cheap one. The housing and rotor are made out of cast iron. The rollers are plastic. If I do not put antifreeze in the pump the corrosion will lock the rollers up so the pump will not turn.
/ Cleaning roller pump #26
/ Cleaning roller pump #27
OK, now I see that these pumps, at least some, don't have any tubing inside. I used to donate Platelets and their machines had a system where the tubing that transfered the blood into and out of the machine was placed around a cylindrical form and a wheel with five or six rollers squeezed the tubing against a backing plate. When the wheel rotated the rollers rolled against the tube and pushed the fluid along inside the tube. The fluid never touched anything but the inside of the tube. I was informed by one of the nurses that it was a roller pump. And perhaps it was.
But the link you furnished indicates no tubing at all. So now I can understand where the corrosion is coming from. /forums/images/graemlins/cool.gif
Thanks!
/ Cleaning roller pump #28
Thanks!
/ Cleaning roller pump #29
Gary we both learned something today as I wasn't aware why it was called a roller pump either. Makes perfect sense now.
/ Cleaning roller pump #30
/ Cleaning roller pump #31
</font><font color="blue" class="small">( I used to donate Platelets )</font>
I guess I'm going to have to try that sometime; never did the platelets; just regular whole blood and the double red cell. Of course the double red takes longer, but not bad. How long does the platelet donation take?
/ Cleaning roller pump #32
Thanks for the help folks. Doesn't solve my problem in that it seems an awful lot of work to unscrew the hose clamps and put in antifreeze each time. I guess I'm the dim bulb here. Do you pour the stuff in, submerse the pump..etc? How do I plumb this for quick disconnect fittings, if possible. I have screw in fittings to the pump, and the slide in male end into the hose with screw on clamps.
/ Cleaning roller pump #35
I just pour the antifreeze in to tank. The suction fitting is in the bottom of tank. Only requires a couple of cups to get it to pump.
/ Cleaning roller pump #36
/ Cleaning roller pump #37
Ron's method should work just fine. I had a filter (actually just a fine screen) in the line before my pump and simply a short piece of garden hose between the filter and the pump, so it was easy to just unscrew the hose from the filter and pour the antifreeze into the pump.
/ Cleaning roller pump #38
/ Cleaning roller pump #39
rinse tank and pump with water.. soap if necescary.. then i add some eco friendly propyl antifreeze and water mix and run it thru a bit and just leave it there.. the propyl is not toxic, and the antifreeze will prevent freezing, and has corrosion inhibiitors, and has water pump lube built in..
Soundguy
/ Cleaning roller pump #40
Soundguy
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
Atspower Mini Excavator (A60352)
Atspower Mini...
