Cleaning out septic system?
/ Cleaning out septic system? #21
Doc Bob: I have a cabin Sawyer county, Brother has a house. He has tossed the little yellow card for the last few years. It is a DNR pushed item. It would take me 200 years to fill my cabin system. They want it pumped every 6 years. The local guy said he would have to pump it just after deer season, when we have some fluids ( beer) in it. I have tossed the last few cards in a pile. The brother did get his system pumped as it did freeze up the year befor. Took some interesting methods to get the turds rolling again on that one.
Well, my septic was pumped today. Verdict after 2 years, no scum and only 6 inches of sludge (barely).
The felllow who pumped my tank (septic system "colonscopy") tells me the little yellow cards only come for tanks built after 1979 (don't know if this is true?). He tells me since my tank built 1973, he suspects there are no records of my system, so no yellow card.
Bob
texbaylea said:
Here is the link to a delightful book: "The Septic Systems Owners Manual".
The Septic System Owner's Manual
Lots of good information about the care of a septic system plus other information you don't really need like the history of same. MossRoad is right as to the best way to restart a septic system.
Vernon
Vernon, I got the book at the library last night. Great book! Thanks, Bob
/ Cleaning out septic system? #25
Doc_Bob said:
The fellow who pumped my tank (septic system "colonscopy") tells me the little yellow cards only come for tanks built after 1979 (don't know if this is true?). He tells me since my tank built 1973, he suspects there are no records of my system, so no yellow card.
Bob
Bob - that is correct for WI. Ours is '72 and no yellow cards. You may be able to find records at the courthouse. We were able to find ours at the Jefferson county court house in the zoning office. They needed the approximate date of installation and the name of the original builder or owner. The more info the better the chance of finding the info. With the year of our construction, the builder, the original owner, and the property description at the time of construction they found ours in about 10 minutes. It did not have a drawing which is what I was really hoping for but it did have a description of the leach bed size.
Well info is available from the state using a form from the DNR.
/ Cleaning out septic system? #26
I see your pumper has heated valves on his truck. I have heated valves and heated pump on mine. The antifreeze circulates from the engine to water jackets built above valve to vacuum pump back to coolant system. In winter I plug in block heater and circulator pump at back of truck. It does use up the electricity. plowking
I did not notice, never even thought to look or ask. The fellow who did the pumping was very good and helpful.
He suggested pumping every 2 years. My wife wants it pumped every two years. Me? I want to inspect it every two years, pump as needed and then save some money. I tried to convince my wife that pumping every two years is a waste of money, "like flushing it down the toilet" :D .
Bob
I am afraid to ask any questions. The less the State knows, the less I have to deal with them. I had my well water tested by the state lab, checks out fine. I figure the State lab does not communicate with anyone, so I am safe. I chlorinate it every 6 months with 3 quarts of Chlorox diluted in a 5 gallon bucket (when I go on vacation) and let it set for a week.
Bob
/ Cleaning out septic system? #29
Ok, heres a question. My farm house is 75 years old and I have no idea how old the septic tank is, I doubt it was an original install with new construction. My guess is it was installed years later. Anyways, I have an idea where the septic tank is cause I can follow the drains in the basement to about where it leaves the house. Is there a way to actually locate the lid to the tank without digging up the entire area? Is there metal on the lids that I could use a metal detector or something?
/ Cleaning out septic system? #30
My lid is concrete with a small re-bar handle. I found mine with a 3/8 metal rod sharpened, pretty easy
Jim
get this book The Septic System Owner's Manual. I got it from the local library. Suggests using rebar, but be careful about poking around in the drainfiled with rebar. Be gentle, mark where you have been. Search in a grid pattern. You already know where it should be, so you have a great start.
Bob
/ Cleaning out septic system? #32
I used a stick of rebar and a small sledge, like a 3lber, and it was very obvious when I hit the concrete lid.
Long ago some folks used cedar planks as "lids" so it is hard to say what might top off the old style tank. It was probably built in place with bricks and mortar. If your soils are good it may even be a cesspool. Likely no steel in the 75 YO tank.
Oh and you know the top of the tank will be no higher in elevation than the pipe that leaves the farmhouse.
/ Cleaning out septic system? #33
If you have an old electrician's fish tape, or a new one you are willing to sacrifice, you can push it down a cleanout and then find the far end with a tracer wire finder, or line locator.
You can rent line locators.
This would save a lot of walking and probing. I would be careful -- if your tank is old enough to have a wooden cover you could potentially fall through it. The gas space in a septic tank is not full of breathable air -- people have died from entering a septic tank.
I have neighbors who would spit on the fish tape, wipe it with a shirt sleeve and put it right back in their tool collection. You will not catch me doing that...
/ Cleaning out septic system? #34
Be carfull Not all fish tapes are metallic!! We use this trick all the time to find dielectric fiber cable. Well the purchasig guy found a deal on new fish tapes. They looked just like the old metal tapes. Locater would not work. Finaly looked at the tape NON-Metallic for safety. Back to the truck for the old tape.
/ Cleaning out septic system? #35
Bob
Doc Bob - here is a chart Septic Tank Pumping Guide: When, Why, How to pump out the septic tank - septic tank cleanout advice I will be using to figure what my pumping schedule should be. As we just moved here and it was pumped, by requirement for the sale, I plan to have it pumped next year (year 3) and check the condition. If the chart is correct it should only be half way to needing a pumping. If that is true I will use the 6 year figure. As we are careful with the system I expect I will find a 6 year cycle will be OK.
/ Cleaning out septic system? #37
I vote be conservative - redoing the leaching field is very expensive if you screw up.
Out here, its charged by the gallon, so there's really no benefit in waiting. A gallon of solids is a gallon of solids... But I'd have it done either while on vacation or after a vacation, so you aren't paying for water to be pumped.
/ Cleaning out septic system? #38
Unless your tank leaks, and it shouldn't, it's full all the time. Inlet & outlet are both at the top. Unless of course you take several month vacations. MikeD74T
/ Cleaning out septic system? #39
A lot of people don't realize that the tank sits full all of the time with a thick layer of floating scum on top and the mudlike sludge on the bottom. The scum can be dark colored or it can look (and feel) like mashed potatoes. Many folks lift a lid and see the mashed potates near the top and think that it is full to the brim and needs immediate pumpage, not so.
These two layers get thicker over time at the expense of a shrinking center clear zone. The clear zone is in the middle where the incoming sewage drops it's solids and the lighter scums float up to leave a clearer effluent to pour into the drainfield. So, the longer you wait, the less efficient the tank becomes since the active volume of the tank is the clear zone and a smaller clear zone means the sewage spends less time in the tank.
Sewage is so cool. Onsite treament is even cooler. My tank pumper charger by the gallonage of the tank (almost always a 1000 gallon tank here in WA)and will always empty it. They can't only pump the sludge and scum since there is no way to know until the mashed potatoes go away.
2019 KOHLER 38RCL Generator DISCONNECT ATS 38KW 315 HORS (A66734)
2019 KOHLER 38RCL...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
