Oil & Fuel Cleaning off Diesel
/ Cleaning off Diesel #1
futuorganics
What is the best way to clean off diesel fuel from the body of the tractor?
/ Cleaning off Diesel #2
A hot pressure washer with a degreasing detergent.
Is this a long term build up or just after spill some from filling her up.
If you have a lot of build up you could always go to a truck stop and have the whole tracotr washed down real good with the hot pressure washer.
/ Cleaning off Diesel #3
I'd recommend using a little Simple Green degreaser. Its organic, unlike alot of degreasers. I use it on any painted parts, and have never had it discolor anything. There are some powerful degreasers out there you wouldn't want to use on anything painted.... they can do a number on your finish !
Where can I get some "Simple Degreaser"?
Futu
/ Cleaning off Diesel #5
Most auto parts stores or walmart carry it.. Check the automotive section in the cleaning area..
good luck
/ Cleaning off Diesel #6
Simple Green is a wonderful product.
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
2011 CASCADIA 6X4 T/A DUMP TRUCK (A59914)
2011 CASCADIA 6X4...
John Deere 490E Excavator (A62679)
John Deere 490E...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
