Cleaning lawn of branches
   / Cleaning lawn of branches #1
WinterDeere
Super Star Member
Top Poster Of Month
Philadelphia
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Every spring, I spend at least a full afternoon cleaning up downed branches from my ~4 acres of lawn, mostly from the more mature walnut and maple trees. I get to repeat this exercise after each major storm, all summer long, and I'm getting awful tired of the routine. Presently, I drive the FEL to an area with a bunch of downed branches, pick up each larger one and put them into the bucket. Then I rake up all of the smaller bits, and scoop them into the bucket. Very tedious.
I'm wondering what automated options might be possible. A landscape rake with float (anti-scalp) wheels would do half the job, at least gathering them together. Although driving over them in the process is just going to make them harder to pick up, in the end. Perhaps a tooth bar on my bucket, fitted with large swivel caster mounts on either side, so that I can drive around gathering branches with the bucket floating just an inch off the lawn.
Ideas? I can't be the only one hating this chore.
   / Cleaning lawn of branches #2
I have a tooth bar on my bucket. I'd rather use a landscape rake instead for this, but it's not going to get the bits and pieces that you need to get up in order to mow your yard.
   / Cleaning lawn of branches #3
On 3-1/2 acres with a fair number of trees I have branches down in the Spring and after T-storms. My routine is to pick up the larger ones and mow over the rest. Anything that isn't larger in diameter than my thumb gets chopped by the 7-1/2' Caroni finish mower.
   / Cleaning lawn of branches #4
I used a landscape rake a few weeks ago. It dragged the bigger stuff and essentially chipped/shredded the smaller stuff to where it didn't matter. When I got done, I couldn't really tell where the material had been.
If you don't want to buy one, look around at rental shps. They might just have one.
   / Cleaning lawn of branches #6
I’m interested in possible solutions too. I surrounded by a dozen 80-100 year old pecan trees. They are notorious for self-pruning, twigs to thigh sized limbs. Note: do not park or build anything of value under them. My solution so far:
   / Cleaning lawn of branches #7
Picking up branches is a chore for us too. Wife does most of the small stuff. EA wicked grapple can pick up a pencil or cleanly pick up a pile. Often picking multiple piles at a time. Been most helpful.
   / Cleaning lawn of branches #9
I do the same….
I'm with you guys, I've started just focusing on the bigger stuff, and mowing over anything smaller. But it seems the vast majority of the branches coming out of the walnuts are 1" to 2.5" diameter, just a little on the large side for mowing.
Bummer to hear there's not a good bucket option, as it'd be ideal for capturing the branches, for dumping straight into the fire pit without further interaction. The landscape rake may gather then a bit, but in the end I still need to hop off the tractor to pick them up by other means.
What technique do you guys use with your landscape rakes, to avoid just driving over the branches and forcing them into the sod?
2003 Big Tex 10PI...
CAT 350E2 Haul Truck (A55272)
CAT 350E2 Haul...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 John Deere 5225 56HP Utility Tractor (A55973)
2007 John Deere...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
