Cleaning engine panels
/ Cleaning engine panels #1
scoutcub
Veteran Member
Ohio
Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
Ok ive tried most everything.....wet sanding....rubbing compound....polishing compound....how can i make the yellow panels white again?
/ Cleaning engine panels #3
If you've tried rubbing compound it appears the existing paint has changed color over time - not uncommon. That being the case Richard above has the answer - prep the surface and paint it.
