Cleaning cylinder shafts and flushing hoses?
   / Cleaning cylinder shafts and flushing hoses? #1
tachnem
NOVA
a ford and a deere
This JD 51 loader has been sitting outside for a bit. This gunk seems to come off with my fingernail. What's the easiest and safest way to get it off without scratching the cylinder rod?
The hoses all have quick-connect fittings on them and seem to be full of fluid. I'm guessing there's probably some moisture in there, what's the easiest way to flush the hoses out?
Thanks.
   / Cleaning cylinder shafts and flushing hoses? #2
the gunk you speak of is rust....it's bit too late for a perfect clean up, but scotch-brite pads or a mild abrasive chrome cleaner may help.....then keep them oiled or greased when you are not using the loader
New rods and a repack will be on the future menu to make them whole again
UNUSED LANDHERO CHAINS, BINDERS & DBL CHAIN SLINGS (A54757)
UNUSED LANDHERO...
Polaris ATV (A50324)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
