Cleaning air filter
   / Cleaning air filter #1
Itawamba1
Fulton, ms
Massey ferguson 235
I have no air compressor. Could I just clean the outer air filter of my MF 235 with a water hose, let dry, reinstall, and keep on ranching?
Bob W
   / Cleaning air filter #2
Bob W
Use a shop van on either BLOW or VACUUM, works good enough with no compressor. Water will deform the filter media and if too wet blow a hole in it, and what's not cleaned will tuen into hard mud like cement darn near, so no air gets through after the water wash.
Thanks so much. Bob w
   / Cleaning air filter #4
Most OEM specs say to just tap the filter gently on the tire while rotating it to dislodge loose dirt. That will work to remove enough dirt for the filter to be used again.
   / Cleaning air filter #5
Just reread this, While rotating the filter, not the tire. Just so everything is clear.
   / Cleaning air filter #6
Is there any Aggies on here ? Just sayin'
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
Miles read : 112,969 (A50323)
Miles read ...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
