Cleaning a quick coupler.
/ Cleaning a quick coupler. #1
swampvol
SC
Kubota l3400HST TLB
I used it to check my psi's, then instead of putting it in a zip-lock, I let it sit on the bench and collect dust/dirt. I need to use it now to replace the leaking one on my backhoe.
Is there anything I can soak it in, or should I just blow it with the air compressor?
Thanks.
/ Cleaning a quick coupler. #2
Thanks.
Dip it in diesel, blo it off/out....repeat.
larry
/ Cleaning a quick coupler. #3
I've sprayed mine with CRC Freeze OFF if the coupler is sticking from rust. plowking
/ Cleaning a quick coupler. #4
WD40 works well for cleaning also...
/ Cleaning a quick coupler. #5
I always clean my QD's with a spray can of wd-40 and the lil red straw.... it's about the only thing that stuff is good for.. that and displacing water off a distrib cap...
soundguy
2011 Ford F-550 4x4 Terex Hi-Ranger LT38 38ft Insulated Bucket Truck (A61568)
2011 Ford F-550...
Kuhn FC400RG (A60462)
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2025 LandHonor PF-11-3500G 42in Forks and Frame Skid Steer Attachment (A60353)
2025 LandHonor...
New/Unused 60in Pallet Forks (A61166)
New/Unused 60in...
