Cleaning a quick coupler.
/ Cleaning a quick coupler. #1
swampvol
Gold Member
SC
Kubota l3400HST TLB
I used it to check my psi's, then instead of putting it in a zip-lock, I let it sit on the bench and collect dust/dirt. I need to use it now to replace the leaking one on my backhoe.
Is there anything I can soak it in, or should I just blow it with the air compressor?
Thanks.
/ Cleaning a quick coupler. #2
Thanks.
Dip it in diesel, blo it off/out....repeat.
larry
/ Cleaning a quick coupler. #3
I've sprayed mine with CRC Freeze OFF if the coupler is sticking from rust. plowking
/ Cleaning a quick coupler. #4
WD40 works well for cleaning also...
/ Cleaning a quick coupler. #5
I always clean my QD's with a spray can of wd-40 and the lil red straw.... it's about the only thing that stuff is good for.. that and displacing water off a distrib cap...
soundguy
2013 APPCO T-BELT TRAILER (A67714)
2013 APPCO T-BELT...
335 GAL WATER TANK (A68842)
335 GAL WATER TANK...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
Unused 2022 Land Pride QH30 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2022 Land...
PALLET OF LIFTING STRAPS (A68842)
PALLET OF LIFTING...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
