Clean your transmission strainer!!!!!
/ Clean your transmission strainer!!!!! #1
Goreef
Smithville Texas
mahindra 6530 4x4 2013 .Bought at J5. Great dealer,i would highly recommend
Just a heads up. I was trying to decide if i was going to clean my transmission strainer when i done the 50 hour service.I read a bunch of post about the subject with about a 50/50 split of people saying yes its important to do while others said that the dealer told them it could wait till the 1000 hour service. So i came to the conclusion that the engineers at Mahindra put this in the manual for a reason and Boy were they right. I found alot teflon tape stuck in the strainer along with metal flakes. So dont be lazy its only an extra 30 minutes to protect you machine.
/ Clean your transmission strainer!!!!! #2
If the debris is truly "caught" in the strainer, it matters not if they are subsequently removed from the tractor by cleaning the strainer. (As long as fluid flow is not obstructed significantly)
It's the little bits that"get away" that are the concern. I like to add magnets to everything. ;-)
/ Clean your transmission strainer!!!!! #3
That is why we never recommend Teflon tape on hydraulic fittings. Unless it is done with the upmost care, some of it gets into the system and can cause a lot of grief if caught in a relief or spool valve.
Good for you for checking the strainer.
/ Clean your transmission strainer!!!!! #4
When I did my 50 hour service the plugs were way over coated with Teflon tape from the factory. At first I thought it was pipe dope but it came off in long strands so it had to be tape.
/ Clean your transmission strainer!!!!! #5
G'day Mate and welcome to TBN from Downunder.
It's always a good thing to follow your owners manual recommendations & good on'ya for reading yours. I won't bad-mouth Mahindra (we try not to do that regarding any colour tractor, here on TBN), however I've read here that the 'translation' from Hindi to English can be, um, interesting. :)
My first Hydraulic change (fluid & filter) was at 400hrs. Only a few flecks of metal in the filter, but the rig now runs just a wee bit better for having done it.
Yes I did notice the pump and gear train seem to be less noisy after the fluid and filter change
/ Clean your transmission strainer!!!!! #7
I think that is unacceptable, honestly. They are asking for problems.
/ Clean your transmission strainer!!!!! #8
I've been a believer and user of teflon paste for some years now. It works better and the best part is it's good to use for just about anything water, oil, gas, etc. etc. while with tape you have to get the right kind for the job you're doing. Paste just works and seals better too.
/ Clean your transmission strainer!!!!! #9
I've used Tru-Blu for years with great success. It is quick drying and remains flexible unlike a lot of the thread sealants sold. It also contains Teflon for ease of assembly. Here is a link to show what it is. I always buy the small tube as the can will dry up long before you ever use it all.
RectorSeal(R) Tru-Blu™ - RectorSeal
As an aside I worked on hydraulic governors on hydro generators and if someone saw you near the governor with Teflon tape you'd be run out of the powerhouse. Here is a picture of the rotor. These units were fairly large. The rotor alone weighed 575 tons.
/ Clean your transmission strainer!!!!! #10
What's the guy with that little engine hoist fixin to do, lift a bolt, nut or maybe a wrench?
/ Clean your transmission strainer!!!!! #11
We load the coupling bolts on the flange of the generator coupling so they are ready to use when the rotor is set. If you look close in the center of the lifting beam I'm flagging the load. We use two cranes tied together and you have to control the level using 4 separate hooks. Sitting on the rotor shaft in front of me is a master level that has .0005 divisions. You have 5/8" clearance between rotor and stator. So when you lower it into place you are constantly spending up or slowing down the hooks to maintain level. You can see the lifting beam arrangement. The two smaller beams hook onto the main beam which is hooked onto the rotor. There is a lot to this operation but I've covered the basics. :)
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2022 EZ-GO ELITE...
