Clean the DPF like big trucks do?
   / Clean the DPF like big trucks do? #1
breadtrk
Platinum Member
ashland city, tn
XR 3037 HST Cab
Can we clean the dpf filter like we do on the big trucks?
   / Clean the DPF like big trucks do? #2
Technically, yes. It may be harder to get to than on the big trucks.
   / Clean the DPF like big trucks do? #3
Pretty easy to get to on mine. You can use 1 part pool acid and 4 parts water and soak for 20 minutes then rinse well. Should remove all the ash..... Soot will turn to ash during regen. Not sure if I would do the DOC (burner) the way, but it should be OK
It's right on top, should be easier than plug#8 on a chevy with AC.
I'll use the same stuff I use on the Detroit. I clean it every 250,000miles and have had no emissions related issues in 1.4million miles.
I just didn't know if was the honeycomb design the truck has or something else.
   / Clean the DPF like big trucks do? #5
Same thing..... as far as I know in my 3135
   / Clean the DPF like big trucks do? #6
ON mine the DPF is easy the DOC is in just before the DPF and it look like you have to pull the pipe from the turbo to get it out. DOC has a diesel burner to heat the whole thing. SO you have a fuel line and an igniter in that section.
   / Clean the DPF like big trucks do? #7
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
