Clean the DPF like big trucks do?
   / Clean the DPF like big trucks do? #1
breadtrk
ashland city, tn
XR 3037 HST Cab
Can we clean the dpf filter like we do on the big trucks?
   / Clean the DPF like big trucks do? #2
Technically, yes. It may be harder to get to than on the big trucks.
   / Clean the DPF like big trucks do? #3
Pretty easy to get to on mine. You can use 1 part pool acid and 4 parts water and soak for 20 minutes then rinse well. Should remove all the ash..... Soot will turn to ash during regen. Not sure if I would do the DOC (burner) the way, but it should be OK
It's right on top, should be easier than plug#8 on a chevy with AC.
I'll use the same stuff I use on the Detroit. I clean it every 250,000miles and have had no emissions related issues in 1.4million miles.
I just didn't know if was the honeycomb design the truck has or something else.
   / Clean the DPF like big trucks do? #5
Same thing..... as far as I know in my 3135
   / Clean the DPF like big trucks do? #6
ON mine the DPF is easy the DOC is in just before the DPF and it look like you have to pull the pipe from the turbo to get it out. DOC has a diesel burner to heat the whole thing. SO you have a fuel line and an igniter in that section.
   / Clean the DPF like big trucks do? #7
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2005 Dodge Grand Caravan Van (A55853)
2005 Dodge Grand...
Mini Standing Fire Pit (A55758)
Mini Standing Fire...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
