Clay sticking to bucket
   / Clay sticking to bucket #1
H8Monday
Payson, Utah
LS MT1 25
I have to dig about 300' of trench in clay, and it keeps sticking to the bucket and clogging the bucket. It won't dump out. What do you use to keep the clay from sticking to the inside of the bucket?
   / Clay sticking to bucket #2
I have seen the chain method that requires some fabrication and if you are using a small machine is probably not that effective. The most effective is probably to take smaller bites, skim a few inches off at a time and don't try and remove heaping buckets.
   / Clay sticking to bucket #3
Nothing I know of. Usually a bigger bucket. If my 12" did that, I would use my 24" Yes, it's a HUGE pain when you want to get er done!
Anyone lube the bucket? Spray diesel from a yard sprayer?
I'm using a small 9" bucket on a small machine. Putting in a water line 48" down, so it won't freeze.
Shovel works.
It takes nearly as long to dig the dirt out of the bucket with a shovel as it does to just dig the hole with a shovel
   / Clay sticking to bucket #10
It sticks when it's at just the right moisture level. Super dry and it falls out, super wet and it falls out. I have a 24 inch bucket and I've tried everything ever posts on the internet. Nothing works. Lubricating the bucket only lasts a few cycles, then its sticking again. You would almost have to lubricate it after you dump it every time. I tried special paint that was guaranteed to stop anything from sticking to it, which worked until it wore off after half a dozen loads that cost $100 a gallon. I tried only filling my bucket half way and digging shallower cuts, but that just slowed down how fast I could dig, and still stuck to the bucket.
Run a hose in the ditch and keep it super wet, or dig out the bucket every five cycles before it compacts too tight to get it out easily.
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
6ft LandPride Box Blade (A51573)
6ft LandPride Box...
