Clay sticking to bucket
   / Clay sticking to bucket #1
H8Monday
Payson, Utah
LS MT1 25
I have to dig about 300' of trench in clay, and it keeps sticking to the bucket and clogging the bucket. It won't dump out. What do you use to keep the clay from sticking to the inside of the bucket?
Thanks
   / Clay sticking to bucket #2
I have seen the chain method that requires some fabrication and if you are using a small machine is probably not that effective. The most effective is probably to take smaller bites, skim a few inches off at a time and don't try and remove heaping buckets.
   / Clay sticking to bucket #3
Nothing I know of. Usually a bigger bucket. If my 12" did that, I would use my 24" Yes, it's a HUGE pain when you want to get er done!
Anyone lube the bucket? Spray diesel from a yard sprayer?
I'm using a small 9" bucket on a small machine. Putting in a water line 48" down, so it won't freeze.
Shovel works.
It takes nearly as long to dig the dirt out of the bucket with a shovel as it does to just dig the hole with a shovel
   / Clay sticking to bucket #10
It sticks when it's at just the right moisture level. Super dry and it falls out, super wet and it falls out. I have a 24 inch bucket and I've tried everything ever posts on the internet. Nothing works. Lubricating the bucket only lasts a few cycles, then its sticking again. You would almost have to lubricate it after you dump it every time. I tried special paint that was guaranteed to stop anything from sticking to it, which worked until it wore off after half a dozen loads that cost $100 a gallon. I tried only filling my bucket half way and digging shallower cuts, but that just slowed down how fast I could dig, and still stuck to the bucket.
Run a hose in the ditch and keep it super wet, or dig out the bucket every five cycles before it compacts too tight to get it out easily.
2025 14ft. Bi-Parting Driveway Gate (A55853)
2025 14ft...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2012 Jeep Grand Cherokee (A56859)
2012 Jeep Grand...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
New Holland WorkMaster 37 (A53317)
New Holland...
