Clay sticking to bucket
   / Clay sticking to bucket #21
DJ54's method works for me also. When I first got our backhoe with a 12 inch bucket I was having the same problem. Very frustrating to be sure. I called a neighbor who operated equipment for a living to teach me how to dig a trench. His method was like what DJ54 said. Just don't scoop like ice cream. Rick
   / Clay sticking to bucket #22
Down here, you'd just wait a week.
   / Clay sticking to bucket #23
Clean the bucket of any it or rough surfaces. If needed, use a sandpaper wet/dry. Use no course sandpaper or grinder wheels or anything that De's not make the surfaces smooth. (no grinder marks - none). Then get a spray polymer. Not paint, not oil, not any spray lubricants. Just spray polymer (because a polymer doesn't coat, it attaches).
Spray a light coat and let cure for 2 or 3 hours. Spray a second time, dry, spray a 3rd time - each time it doesn't matter that it feels dry and 15 minutes - dry for a couple hours each time.
If done right, it will feel slippery and not just smooth or greasy. Good luck.
   / Clay sticking to bucket #24
I think a vent oil in the back of the bucket might work to relieve the vacuum hold that the wet clay has. I think that is the more powerful agent working to keep the soil from dumping. I don't think it would have to be a very big hole in order to work.
If you cut a hole, save the plug so you can weld it back in if needed.
   / Clay sticking to bucket #25
It might work to spray with used motor oil every few scoops. Never tried it though. Some kid would be happy to make a few bucks to stand there and spray.
   / Clay sticking to bucket #26
Yet to find anything that works good :( hand hoe does help when it get bad enough.
DeWalt Pressure Washer (A56469)
DeWalt Pressure...
2015 Ford F-550 Altec AT40M 40ft. Bucket Truck (A55852)
2015 Ford F-550...
(4) KUBOTA TRACTOR RIMS (A57192)
(4) KUBOTA TRACTOR...
2018 CASE TR310 SKID STEER (A52707)
2018 CASE TR310...
UNUSED JCT HYD BACKHOE DIGGER ARM (A57193)
UNUSED JCT HYD...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
