Clay Fill Question
   / Clay Fill Question #1
HawkinsHollow
Veteran Member
SE TN
Branson 3015R
Finally found some clean fill dirt. The school I work at is having a bunch of construction done and they are digging footers for a new gym. This fill will come from there. I am going to use this fill to level an area that was filled with larger stone, brick and block. My question is: I would like to make this an area that can grow some decent grass. how do I enrich this fill dirt to create a nice substrate for grass? This is straight Georgia clay, zero organics, nutrients. How do I get some organics and nutrients into it to make it better to grow grass?
   / Clay Fill Question #2
you can till in after it is level peat moss cow or horse manure sawdust it will all help
   / Clay Fill Question #4
Why not skim coat it with 4-6" of topsoil?
   / Clay Fill Question #5
how large an area? that will determine materials, cost, labor. do you have a city source for compost? that alone would make difference. that would be my choice for soil amendment once you get that base clay down. maybe look for a bulk topsoil source as well.
how will you spread & work materials on area?
   / Clay Fill Question #6
I have had several people tell me Gypsum works well. Yes drywall. You can buy it in bags at most farm feed stores and some big box stores. I heard farmers use it. It is supposed to help break up the clay and make it more porous. I don't think it works immediately. I hear tilling it in is the best way to go. I put it down like fertilizer for several years at my old house, and not sure if it really did anything. But I talked to some people that said it is great. I think maybe the key is tilling it in at the beginning.
I would look for free cow manure. Can usually find it in rural areas. Rent a dump trailer if you don't have one and till that in. Grass will grow in clay, but dies fast when there's no water.
   / Clay Fill Question #7
...This is straight Georgia clay, zero organics, nutrients. How do I get some organics and nutrients into it to make it better to grow grass?
What color is the clay? If it's red clay, odds are very good that warm weather grass like Bermuda will grow on it very well just as it is. I would also suspect that if you do nothing, in six months it will be overgrown with weeds.
   / Clay Fill Question #8
I mix sand in the cheapest thing I can get then Milorganite using, Pensacola Bahia. It puts in very deep roots, and really good in draughts and frost won't kill the roots. It so strong it won't let weeds grow, just don't mow it too short, and let it seed once a year August.
   / Clay Fill Question #9
What he said.
Don't waste time and money trying to turn fill dirt into topsoil. It can take up to 1000 years to make 3 cm of topsoil!
If you really want to try it, don't mix sand and clay. Sand + clay basically makes cement.
You need to mix in at least an equal proportion to the fill dirt of leaves, manure, sawdust etc. The fill dirt would need to be dry and the mixing would have to be so extensive that I don't see how you could do it.
The problem with clay has less to do with the nutrient mix than it does with the fact that there are no air spaces between the soil particles. Plants drown in it. In order to alleviate that problem, you have get organic particles in between the soil particles so air can get in there. Good luck with that.
Just bite the bullet and get topsoil delivered.
   / Clay Fill Question #10
Topsoil about $450 a load, sand $180. If you want just good grass coverage and erosion control, and want get rid of clays greasy surface sand and anything organic. I put about 2 to 3 inches of sand on top the clay then run the harrow around then chain drag it, look like hand raked then take the leaf blower and use it to spread fertilizer put seed out water lightly for about 3 to 5 days then stay off it. 3 months later you got mowable grass a year later the Bahia roots will pierce the clay and sold coverage that won't erode and drains well. If you want flowers or fancy lawn grass no.
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
2013 Chevrolet Silverado 3500HD Crew Cab Omaha Service Truck (A48081)
2013 Chevrolet...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2018 John Deere S780 Combine (A50657)
2018 John Deere...
1993 Ford F-350 4WD Ambulance Truck (A50860)
1993 Ford F-350...
