Clamp-on vs QA pallet forks
   / Clamp-on vs QA pallet forks #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
Hi all. Occasionally I have the need to remove 3 heavy pallets from my trailer. Currently, I am using clamp-on forks on my tractor FEL. Sometimes, no matter how tight I clamp them on, they shift. I am considering QA forks but I am concerned that if I misalign and put downward pressure of the forks that the QA forks will just jump off or out of position anyway. Rarely do I get a good view of where the forks are entering the pallets. Do the forks lock into position? If not, I would probably consider this a waste of money. Any advice would be appreciated.
   / Clamp-on vs QA pallet forks #2
Any ssqa pallet forks that I've seen either lock in place, or are hydraulically adjusted. Dedicated pallet forks are going to be much more stable and secure than clamp on forks.
   / Clamp-on vs QA pallet forks #3
Don't even think twice about getting a set of QA forks. You'll be wonder why you didn't get them a long time ago.
Just for the visibility alone, it's well worth it. Yes, most forks do lock in place. It will have just a little bit of play which is there to allow you to slide them but not an issue during use.
The one I use on my tractor, uses the forks from my forklift. When I built the frame, I didn't even bothered with putting the notches so the forks can lock. It really doesn't slide around.
   / Clamp-on vs QA pallet forks #4
I have clampons with the stabilizer. Just did not work well enough for me.
Now I have QA forks, much happier and no worried about bending the bucket lip, or the forks moving and dropping a load.
I guess that I am sold on the QA. Any brand preference?
   / Clamp-on vs QA pallet forks #6
Anything cheap, that meet your requirements. 4000# forks are 4000# forks; doesnt matter if name brand or straight off the boat. Just stay away from the Super cheap, fix position, tube type forks, they might be $150 cheaper, but you're on the wrong 80/20 specturm; your paying 80% price for 20% capability
   / Clamp-on vs QA pallet forks #7
This is what I mean by the cheapest of the cheap, that i would avoid. Maybe they are better than clamp ons, but they arent real forks
   / Clamp-on vs QA pallet forks #8
You will like them. I have the JD style QA and I’ve never had them feel like they will come loose. Get one with a headache rack also, you can see through it and actually see what the forks are doing.
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
QUICK ATTACH SKID STEER HITCH (A57193)
QUICK ATTACH SKID...
UNUSED WOLVERINE MCB-11 48W 48" HYD 4N1 BUCKET (A57193)
UNUSED WOLVERINE...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
