Ck4010SE Roof Access
   / Ck4010SE Roof Access #21
Thanks. Im going to remove tonight and run all the wires. Also installing new led work lights and putting the front and rears on seperate switches.
Hi,
Thanks for the pictures, great job!! I have a fogging problem with my Cab Kioti so I got a good look at the ducting, think I'll insulate as a measure. Can you tell me what kind of LED lights you put in? I want to do the same but want something that looks proper.
   / Ck4010SE Roof Access #22
Hey finn1 - I am having trouble with the 5a fuse for the dome light and radio memory. Is the connector you mention the possible cause? What have you done to correct it?
Thanks in advance!
John E.
   / Ck4010SE Roof Access #23
I had an issue with the pins in the connector in the main wiring harness down near the cab floor on the left side just behind the engine.w
There is a constant power feed through one pin. Story from the Kioti hot line was that the connector was oriented incorrectly such that it wouldn稚 drain properly and water and the cleaning solution they used to pressure wash the tractor after it痴 ocean voyage would get into the plug, not drain, and the pin would dissolve via electrolysis..
The repair was a new plug, installed such that it would drain, not seep into the pins..
Kioti was pretty impressed when the dealer and I figured out what the problem was just by looking at the schematic and doing five minutes of testing with a voltmeter. They said they had seen this issue before but hadn稚 issued a service bulletin. They supposedly were going to develop a service kit, though. Don稚 know if that happened.
Kimball Midwest Wire Cabinet w/Wire (A59076)
Kimball Midwest...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
500 GALLON S/A FUEL TRAILER (A52708)
500 GALLON S/A...
2018 CATERPILLAR 336F L (A58216)
2018 CATERPILLAR...
14C SCRAPER (A58214)
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
