ck3510se, hydraulic leak somewhere on 3pt valve area
   / ck3510se, hydraulic leak somewhere on 3pt valve area #11
After watching your video I think it may actually be coming from this hose.
   / ck3510se, hydraulic leak somewhere on 3pt valve area #12
Tried to make a GIF of a video I took, but still won't let me upload it here. Found somewhere else to upload it, here's the link. https://gifyu.com/image/Xnfr
Not great quality, but gets the point across. Sure looks like just a blown seal (o ring) to me.
You can always upload to youtube and just set it to Private, meaning only those with a link can see it.
Wow, you know what, you might be right. It sure looked like it was where I put the arrow, but I didn't want to get my face or hands too close, and risk getting injured. I watched my original video in slow-mo, and it sure does look like it's coming from the hard line. I think it's the one below where you circled though. I'll have to see if I can get the camera in there, with the tractor off, and see if I can get a picture of the other side of those lines.
Thank you for pointing this out!
   / ck3510se, hydraulic leak somewhere on 3pt valve area #14
Easy way is to slip something, like a piece of scrap plywood, in between and see which side gets wet.
Well, I had to go check again, and turns out, we were sort of both right lol. It IS an O-ring, but it's on the hard line, not on the valve body. Was super easy to get to from under the seat, and it's probably like a dollar for a new o ring. Here's a couple pictures of it. In the 2nd picture, the failed o ring is on the back side of the line, hence why it was spraying oil out from that side.
   / ck3510se, hydraulic leak somewhere on 3pt valve area #17
Looks like a easy repair. Glad you located the problem.
Yep, I was super worried about it last night, seemed like it was going to be a nightmare, and I've still got lots of mowing left to do. Still gotta wait til monday to find the o-ring somewhere locally, but I'll sleep better tonight, knowing that I don't have to spend a fortune or wait for parts. Thanks again for pointing out the actual leak location, really helped me out quite a bit!
   / ck3510se, hydraulic leak somewhere on 3pt valve area #19
I blew plenty of O-rings. The hard line was replaced, the valve body was replaced, and after several 150 mile trips to the dealer, several self repairs, and many months of fighting leaks, I reached out to MIE.
From MIE,
For the return line from the Rear Hydraulic Valve to the Top of the Transmission Case, use Parker O-Ring Number 43005682-116. These are High Pressure / Temperature poly O-Rings. You will need (4) of them, 2 at the valve and 2 at the top of the transmission. Make sure you lubricate the O-Rings and torque the Banjo Bolts to 38ft-lbs. We have not had a single leak since we started installing these O-Rings with the proper Banjo Bolt Torque on all of our CK10SE Tractors a couple years ago. They can be sourced at any Parker Store, or at Mcmaster Carr part number 9558K548.
We do this on every CK10SE Tractor we sell. The "green" o-rings that are used at the factory are suspect....
After purchasing the new O-rings from McMaster Carr, I am glad to say the tractor has not leaked again in over 300 hours.
Thank you MIE,
Carl
   / ck3510se, hydraulic leak somewhere on 3pt valve area #20
Yep, higher temp.. Spec'd for ~60F more.
Normal:
Product Features:
  • Size -116
  • 90A Durometer Polyurethane
  • 3/4" Inside Diameter
  • 15/16" Outside Diameter
  • 3/32" Cross Section
Translucent polyurethane is compatible with a variety of chemicals for virtually any sealing application. 90A durometer (hardness) for resistance to penetration and tearing. For use in temperature applications between -60 F to 212 F (-51 C to 100 C). Meets Aerospace Standard AS568A.
______________________________________
Parker Resilon:
Technical Specifications
O-Ring Dash Size: 2-116 Seal Material: P4300A90 Inside Diameter: 0.737 inch Cross Section Width: 0.103 inch Polymer Material Options: Polyurethane (TPU)
Durometer: 90 (Shore A)
Minimum Operating Temperature: -65 °F Maximum Operating Temperature: 275 °F
Chemical Compatibility: Oil, Ozone
Industry: Industrial
Specifications Met: AS568B Sizes, USP Class VI
Not 'cheap' as they are $3 each at McMaster, and the normal ones are $21 for a 25pk, but if they work who cares? :)
Thanks @carsce (y)
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
