CK3510 SE Hydraulic Leak - O Ring / Paint -
   / CK3510 SE Hydraulic Leak - O Ring / Paint - #1
BrkMstr
West Ossipee, NH
Kioti / CK3510se HST
Had an interesting situation, set up my finish mower, raised an lowered a few times, prior to using noticed a drop or two of fluid on floor, thought maybe a few drops from when I changed fluid (50 Hr) a few weeks back, that using arm may moved some splash - took the mower out used it - while backing into garage the flood started :eek: Of course I had just sealed my driveway the day before :mad: Any way traced it back, removed seat etc. looked like it came out of the lift cylinder banjo bolt / line, it looked like the line entering the cylinder was not set tightly against it, but was covered with thick paint, taking it apart I found one split O ring on the leak side - I cleaned it up removed the excess paint - replaced all the O rings / little grease to hold them in place and re-attached. You can see the line, it connects from the rear of the speed control to the lift cylinder - anyway leaks gone no issues - just thought I'd pass it along seemed the factory put it together, did not get it tight and then painted it, the paint most likely sealed it for a while!! Unit has 65hrs on it......
   / CK3510 SE Hydraulic Leak - O Ring / Paint - #2
@BrkMstr
This was the o-ring in red, correct?
At 239 hours, I was screening topsoil today (back and forth between 2 spots) and noticed some oil.
After some cleanup ended up with the seat off and my leak is a drop every 3 seconds from here, I believe this is the opposite end from what you fixed:
Yes it was that line, by the looks the factory had tightened the ends and painted, never noticed or checked that one of the Banjo's was not set right, O ring must not have been set right, split when tightened / off center - I believe the paint held it for awhile until pressure finally blew it apart, it went from a drip to a flood. I cleaned up the threads, replaced all the O rings - no issues......
   / CK3510 SE Hydraulic Leak - O Ring / Paint - #4
Thanks.
I cracked mine loose to break the paint and then snugged it as right as I dare, no change.
Parked the tractor and ordered a pack of o-rings before the flood started. There's a few other threads about this, yours was just the first I found.
   / CK3510 SE Hydraulic Leak - O Ring / Paint - #5
Well this:
Definitely leaks!
Polished the paint off and re-assembled with 4 new 116 size Buna-n 90A o-ring.
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
40' CONTAINER (A51248)
2024 JOHN DEERE 17G LOT IDENTIFIER 251 (A53084)
2024 JOHN DEERE...
12 in Large Excavator Bucket (A52377)
12 in Large...
2017 JOHN DEERE CP690 LOT IDENTIFIER 180 (A53084)
2017 JOHN DEERE...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
