CK35 HST Pedal Problem
   / CK35 HST Pedal Problem #1
mgarner
HST pedal not returning to neutral position without help but ONLY when in high range. In other ranges it operates as it should. Anyone have a
possible solution??
   / CK35 HST Pedal Problem #2
Dunno if this helps..
What is different in my case is that the linkage is free when tractor is in medium or low range but will be really slow returning to center when in high. By slow I mean it takes 10 to 20 seconds if I let it return on its own which means I have to rock it back with my heel. I have gotten use to doing that and unless it is a simple fix I will leave it as is for now but would have some idea what is causing the problem
   / CK35 HST Pedal Problem #4
Did you read the entire thread? If it's still under warranty, have them replace the HST. If not, break out the check book. :(
Long out of warranty so will keep the check book in the desk and keep running it like it is. It has been that way for a few years now and maybe, since I am 87 now it will outlast me. Consider the problem as forgotten.
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
16 ft trailer with gate (A52128)
16 ft trailer with...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
