3-Point Hitch CK30HST - 3 Point hitch stuck in up position - not the seat valve speed adjustment
   / CK30HST - 3 Point hitch stuck in up position - not the seat valve speed adjustment #21
There is a shock-relief in the 3-pt system, set at something like 2900psi. Did you get a BC service
manual?
It does sound like you have some sort of blockage in the MLS valve.
Checked with the dealer Thursday about the Bobcat Service manual. The current price for a PDF version is $124.74. Opted to hold off on the purchase for now. Checked the pump pressure at the rear remotes `2700. Then MLS valve was removed and it appeared to be in pristine condition. I worked the (MLS) spool and regulator piston up and down with my fingers while blowing out the ports with compressed air, put everything back together and the three point is now working fine. Used the tractor for another half hour and all is well. So the failure of the three point to lift does seem to have been related to a blockage in the MLS valve.
Steve
   / CK30HST - 3 Point hitch stuck in up position - not the seat valve speed adjustment #22
That's good news, Steve.
Too bad Bobcat is still outrageous on the PDF manual. Paper, I could see that, but
PDF?
Anyway, you may want to pick up a Kioti CK25/30/35 PDF in the interim. There have
been some free ones floating around, or there is one on eBay now for about $15.
   / CK30HST - 3 Point hitch stuck in up position - not the seat valve speed adjustment #23
Erielly just curious to see how you made out. Having the same problem and was wondering if you we're able to fix yours.
Cushman Electric Cart (A55851)
Cushman Electric...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2001  WABASH 53FT DRY VAN TRAILER (A57880)
2001 WABASH 53FT...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Enmark Z Spray (A53316)
Enmark Z Spray...
