CK30 Work Light Advance Auto $15
/ CK30 Work Light Advance Auto $15 #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
Here's a pic of the $15 work light installed. The kit included a lot of wire and a switch. I used a moto tool to cut a place for the switch on the light housing, snapped it in and secured it with black silicone. Connected the wires to the two smaller connectors, which are ON all the time the lights are on. The switch within the back work light housing allows you to turn the light off when you don't need it.
Mike
/ CK30 Work Light Advance Auto $15 #2
I can't tell exactly where you put it, but do you get good coverage of a work area, say backhoe work, etc.?
I made one on a magetic grounding block so that I can move it around where I need it.
It looks good.
John
Hi John,
It is in the mounting hole meant for the back work light, back right of tractor.
Actually I haven't used it yet, but it is plenty bright.
Mike
/ CK30 Work Light Advance Auto $15 #4
That should probably keep from casting your shadow on the work spot then if it's far enough off to the side. When you're on the backhoe, some light locations are not high enough up, or off to the side enough not to hit the operator.
John
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2018 F550 Bucket Truck (A61306)
2018 F550 Bucket...
Pick up Bed (A60352)
2022 Ram 2500 (A55973)
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
