CK30 Tie Rod replacement, tire alignment help needed! <Resolved>
/ CK30 Tie Rod replacement, tire alignment help needed! <Resolved>
Thank you all for the help. I got it in and adjusted. I will remeasure it tomorrow and lock it down. That should do it.
/ CK30 Tie Rod replacement, tire alignment help needed! <Resolved> #22
SPYDERLK, thank you. As I had mentioned, I was trying to figure out how to pull or push the wheels in or out. I was thinking of using spreader bars or clamps, but I couldn't find any that would work effectively. Your mention of using a come-along got me thinking about how I would attach it, and I used a set of fence stretchers. I didn't need the come-along given the leverage they provided. You were right about moving it incrementally. Once I got the tie-rod in, I could twist that by hand a little at a time as well. Thanks again!
Ya-ay-y-y! I like your rig up. Glad to be of help.
/ CK30 Tie Rod replacement, tire alignment help needed! <Resolved> #23
No point, it's hydrostatic steering.
Yes it is hydrostatic steering, if the system is full the steering motor will act as pump even with the engine off.
The wheels will turn easily especially when suspended in the air.
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
2019 CATERPILLAR 299D3XE SKID STEER (A60429)
2019 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 1.5 Ton Crane Utility Truck (A59230)
2005 Mitsubishi...
KUBOTA SVL97-2 SKID STEER (A60429)
KUBOTA SVL97-2...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
