CK30 Tie Rod replacement, tire alignment help needed! <Resolved>
   / CK30 Tie Rod replacement, tire alignment help needed! <Resolved> #1
Mark_G
Va
Kioti CK30 Synchro Shuttle
I bent the tie rod on my CK30. I removed the old one, and I'm trying to put the new one on. My front tires will not align; they are splayed out at the front (too narrow at the back). If I press on a tire, the other moves too, but without the tie rod, they are splayed such that no matter what I seem to do, I cannot get the tie rod in place. How can I get the tires aligned so I can install the tie rod and then adjust it to achieve the proper toe-in? Any help would be greatly appreciated.
   / CK30 Tie Rod replacement, tire alignment help needed! <Resolved> #2
I dont have a CK30 so I would need pics to diagnose. Cant you block the steered wheel in a position and then move the free wheel to match it? ... Then afterward fine adjust.
The steering wheel spins when I push in on a tire. If the steering wheel is held, I don't think anything will move, but I could try it.
I wonder if I need to disconnect the hydraulic line from one cylinder to bleed some fluid from that side to align the wheels. I should be able to put the tie rod on, then adjust for toe-in, and reinstall the line. I'm not sure if that will interfere with anything, such as the steering center setting, etc.
   / CK30 Tie Rod replacement, tire alignment help needed! <Resolved> #5
Dose the CK use a single cylinder with shafts coming out both ends or a single cylinder driving a tierod on each side.
Just turning the wheel without the engine running should force the cylinder to extend and retract.
In doing so the attached wheel will move the detached one should stay stationary until the tierod is attached.
There are two cylinders, one on each side, which each connect to a wheel, and in the middle to a center point. I will take some pictures.
   / CK30 Tie Rod replacement, tire alignment help needed! <Resolved> #7
Good because every tie rod end I've ever seen is adjustable, just like a car or turck us. No castor and camber on a tractor, just toe in and out.
It will be, I simply need to figure out how!
For fun and frivolity, here are three pictures. The first shows the original bent tie rod. The spacing on the tires looks suspiciously like the reduced length of the bent rod. The second shows (but not super clearly) my tractor on stands and the tires a bit toe out (my issue). The last image shows the right front tire and the hydraulic cylinder used for steering on that side (the left side looks similar), as well as the new tie rod at the bottom, resting near the hole it needs to fit into. The left side of the tie rod is seated in that hole, so the distance shown is what I need to recover to mount the tie rod. Then, I will need to expand it by about 3 inches to achieve the correct alignment. That should be nothing more than turning the tie rod to expand its length. The manual states that I need to adjust the toe to between 2 and 8 mm, measured as the difference between the front and rear of the tires from the center of the tire tread pattern.
   / CK30 Tie Rod replacement, tire alignment help needed! <Resolved> #10
Im going to guess, that if you arranged to pull the forward part of each front tire toward each other the wheels would come into alignment gradually by hydraulic leakage through the steering circuit. Im talking engine OFF and a moderate pull force of 2 or 3 hundred pounds with a come along.
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Hydraulic Thumb Clamp (A57149)
Hydraulic Thumb...
2002-2004 CAT 325C Excavator (A59213)
2002-2004 CAT 325C...
2023 Chevrolet Tahoe FL SUV (A56859)
2023 Chevrolet...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
