CK30 oil change and oil condition
   / CK30 oil change and oil condition #1
Retired guy
Western, ME
CK 30HST
Just finished the 50 hour oil @ 59 hours. The oil coming out was the same color as
the stuff going in--light tan. No soot - no discoloration. On my Kubota, it was black
after about 5 hours on the clock. Is this common?? I was expecting maybe a little
MORE discoloration due to the newness and the fact that the rings had to set, etc.
My serial # begins with an M. Could this be a newer Tier engine?
   / CK30 oil change and oil condition #2
I don't know about your bota but multi weight oils usually discolor fast. What oil you using now?
Rotella T-6. I do not know what came in the engine.
   / CK30 oil change and oil condition #4
How do you like the Kioti compared to your Bota? Check the color of this oil after ten hours.
   / CK30 oil change and oil condition #5
Break in oil is usually non detergent and will not darken as quickly.
   / CK30 oil change and oil condition #6
The factory oil would be non-synthetic; and if you're not seeing a lot of evidence of break-in particulate matter that is not necessarily a bad thing. I seem to remember thinking the same when I drained mine the first time too.
Welcome to TBN and don't forget to add the Kioti to your avatar sig!:thumbsup:
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
Mini Excavator Attachment Set (A50121)
Mini Excavator...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2014 Hitchai ZX470LC-5B Excavator (RIDE AND DRIVE) (A50774)
2014 Hitchai...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
