CK30 oil change and oil condition
   / CK30 oil change and oil condition #1
Retired guy
Western, ME
CK 30HST
Just finished the 50 hour oil @ 59 hours. The oil coming out was the same color as
the stuff going in--light tan. No soot - no discoloration. On my Kubota, it was black
after about 5 hours on the clock. Is this common?? I was expecting maybe a little
MORE discoloration due to the newness and the fact that the rings had to set, etc.
My serial # begins with an M. Could this be a newer Tier engine?
   / CK30 oil change and oil condition #2
I don't know about your bota but multi weight oils usually discolor fast. What oil you using now?
Rotella T-6. I do not know what came in the engine.
   / CK30 oil change and oil condition #4
How do you like the Kioti compared to your Bota? Check the color of this oil after ten hours.
   / CK30 oil change and oil condition #5
Break in oil is usually non detergent and will not darken as quickly.
   / CK30 oil change and oil condition #6
The factory oil would be non-synthetic; and if you're not seeing a lot of evidence of break-in particulate matter that is not necessarily a bad thing. I seem to remember thinking the same when I drained mine the first time too.
Welcome to TBN and don't forget to add the Kioti to your avatar sig!:thumbsup:
4 Unused Montreal ST205/75R15 Trailer Tires (A50322)
4 Unused Montreal...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
PT 500 Gal Water Tank (A50121)
PT 500 Gal Water...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
New 3pt Sod Cutter (A50774)
New 3pt Sod Cutter...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
